AMD Ryzen 5 2400G and Ryzen 3 2200G Reviews
February 12, 2018 | 14:00
Tags: #accelerated-processing-unit #apu #cpu #infinity-fabric #radeon #rtg #ryzen #vega #zen
Companies: #amd
3DMark
Publisher: Futuremark
3DMark is arguably the most popular synthetic benchmark around today. For integrated graphics, we run Fire Strike (DirectX 11) and Time Spy (DirectX 12), both with default settings. Anyone can download and run the Fire Strike and Time Spy benchmarks for free using these same settings, so you can easily compare your own system's score with those you see below.
Deus Ex: Mankind Divided
Publisher: Square Enix Holdings
Deus Ex: Mankind Divided is a DirectX 12 title. We test integrated graphics using the Low and Medium presets at 1,920 x 1,080. We run the built-in benchmark (hidden in the Extras menu), as it is very consistent and makes full use of the engine's features. We also rely on the game's own frame rate counter since FRAPS does not currently work with this game when using DirectX 12. We've actually found that your experience in-game will typically be with frame rates a little higher than the average frame rate from the benchmark, but even so it's the minimum frame rate that we focus on and that you should really take into consideration, because it's in the most challenging parts of the game that you'll really feel the slowdowns, and it's no good having a sub-par experience in the heat of battle.
Middle-Earth: Shadow of War
Publisher: Warner Bros. Interactive Entertainment
Middle-Earth: Shadow of War serves as a punishing example of the older DirectX 11 API. We run the game's built-in benchmark (accessible from the main menu) and report using the metrics it gives us at the end. At a resolution of 1,920 x 1,080, the Graphical Quality settings are set to Lowest and Medium with no further changes made.
null
